where to install oil pressure gauge?
race_to_live
Post by race_to_live »
I want to put an oil pressure gauge(mechanical) on the car before I start it up for the first time. So while I was at the parts store getting oil I picked up a gauge. So where do I tap in on the engine? Do I actuall have to tap a hole?
-91ss, 250,000mi rebuilt, tmic, tdo4, agx's w/groundcontrol, f/r strut bars, rust
-83 gl wagon...350,000mi custom dents
-62 honda 55, (moped)
-74 Yamaha rd 350
Take it from the plug in the back of the main oil galley. There is plenty of room to tap a 1/8 NPT hole.
Also, if using a mechanical gauge, throw away any nylon or copper tubing that came with it, and go get a proper -3 braided line for it. I made the mistake of not doing that right away and ended up with a lubricated dash.
race_to_live
you are talking about the one on the #2,4 side. right next to the rear breather tube thing?
-74 Yamaha rd 350
On the passenger side, in the back.
I take my oil pressure from my turbo feed, so I'll be installing my oil temp probe there.
fishbone79
Post by fishbone79 »
+1 on the correct braided line... The copper will last a long while (5 years for me), but if it gets disturbed it will play oil fire hose all over the inside of your dash.
Cheers,
morgan
1992 Legacy BF
fishbone79 wrote: but if it gets disturbed it will play oil fire hose all over the inside of your dash.
LOL! :-D Picturing a small oil "fire hose" in your dash makes me laugh.
Or you could get an electronic gauge so you don't risk shooting hot oil around the inside of your dash. :)
race_to_live
what about on the oil pump its self? can i put one there, on one of the plugs on the bottom of it?
-74 Yamaha rd 350
Post by SILINC3R »
can you use a oil pressure gauge to tell you if your low.
I spent about $40 at anplumbing.com to make a braided line work. Obviously an electric gauge is more ideal, but at the time the electric Autometer Cobalt gauges were running about $200 a piece. They've come down in price since.
Mine made a decent mess when it leaked. It didn't spray oil everywhere, but it seeped oil from the pinched nylon line. With my gauge pod on the dash, the foam between the vinyl and the plastic soaked up oil and continued to weep oil for the next year and a half. Also, my CD player stopped playing CD's when it got oil on it.
I learned the lesson the hard way, although it could have been worse. I do not wish that upon anyone else. I won't touch that crappy nylon line ever again, even for a boost gauge. That crap kinks if you merely look at it funny.
Just curious, has anyone seen a combination electronic oil pressure & temp sensor? Idealy, it would be nice to have that information to send back to the Link.
