Here is the relay wiring diagram i used. (followed to the T)
and here is the harness pinout for the unit.
I am using the H1/5 green/black wire (Lock #30 common output) for the (-) lock output at 85 of the first relay and am using the H1/8 blue/black wire (Unlock #30 common output) for the (-) unlock output at 85 of the second relay.
The unit is hooked up to both power and ground and when the remote is pressed you can here the relays within the unit switching.
I have measured voltages at the relays and both 85 pins are constant 12V always.
Any help would be appreciated. I just can't seem to figure this one out. Thanks.
