gear ratios..
subaruracer755@cs.com
gear ratios..
what was the final speed for the 92 legacys (non turbo)? I can get a rear diff for next to nothing. but I would like to know the final drives of the auto and 5MT, cause im not sure which the parts come from.
ssspoon@aol.com
gear ratios..
Mike my 92 turbo automatic is 3.90.
I have a feeling the non turbos were the same
Some 5MTs with LSD may have been 4.11
There is a metallic sticker on the back of the rear end that gives the ratio
It is often covered in muck so you can't tell it's there
Larry Witherspoon
Larry Witherspoon
Rod_
gear ratios..
As far as i know the N/A manuals were 3.9 and the auto's were 4.111.
The turbos' rear diff was actually 3.545 but had a diff stepper in the gearbox of 1.100 to create an overall of 3.9
cheers, Rod .. in oz
Josh Colombo
gear ratios..
Rod,
Depends on where you are.....down where you are, those are probably the correct gear ratios.
In the states, no normally aspirated mt got a 3.9 ratio. The 92-93 autos got a 3.9 ratio, but all the manuals got 4.111
Rod_
gear ratios..
yeah, good point. weird how they did that - I should have realized that - just finished nightshift - yeah i know -lame excuse !!
cheers, rod
ps but maybe if the parts are jap import i'm pretty sure they are the same as ours...... had to throw that one in...
cheers, rod
