So I picked up another diamond coil pack, to test wiring with, and I'm wondering how do you disconnect the coil from the connector?
SC
Disconnect the coil...
Smithcraft
1994 Legacy Mi
2008 Legacy GT SpecB
Smithcraft
Re: Disconnect the coil...
I just figured it out!
For those that are curious in the future, on the connector, there is a tab that you pull up, which then allows the loom connection to slide out.
SC
SC
1994 Legacy Mi
Mattheww044
you will come across alot of similar clips...
Smithcraft
Uh oh!
The thing that threw me while I was working on the car abit back, as that there didn't seem to be a way to disconnect the side clips. Of course you don't disconnect them. It's like a connector inside of a connector, that has a connector plug into it...
They say that knowing is half the battle!
SC
SC
1994 Legacy Mi
