N1446's '91 Legacy SS/2.5GT
RJ93SS
Post by RJ93SS »
nice work, cant wait to see it finished.
it was cool to see some of those pics. i wanna pull my engine.
N1446
Post by N1446 »
Now that the car is moving under its own power , i discovered this mess after the motor swap ; it now has a new axle and AWD again ,
- since the car was stationary without a motor and the brakes seized from it not moving, i had to haul the car whenever it needed to be moved around the yard , i assume this is the result of pulling an AWD car with seized brakes
N1446 Brutus
91 Legacy SS 5mt 2.5GT Swap
N1446
Post by N1446 »
Latest Update ; My'93-'94 Side marker lights and regular type antenna : 24$; The Journal Post is taking over for now...Linky Link
N1446 Brutus
N1446
Re: N1446's '91 Legacy SS
Post by N1446 »
getting ready to split the case tomorrow - this thing bent so-much i wasn't able to tapout the wristpins
the bend is so severe it restricted the piston from bottoming out so i had to remove it first
serious warp in the rod , the sound from the EJ22T Suicide was MASSIVE rod knock
tomorrow i will actually pull the case apart and see whats in there
i ve already found som large pieces of pison in random places
Got Turbo ?!!
N1446 Brutus
Jeez. Looks like the steering knuckle on my toyota pickup when I crashed it into a parked integra. Bent a solid 1.25" thick steel 90*.
N1446
Post by N1446 »
it spun a bearing and began a reaal bad knock, i imagine at high rpm
i thought it was HLAs to begin
i guess nott !
it was just oil starved ..
N1446 Brutus
N1446
Post by N1446 »
Cyl#1
Cyl#2
Cyl#3
Cyl#4
N1446 Brutus
N1446
Post by N1446 »
i m still looking for the oil squirters ..
N1446 Brutus
N1446
Post by N1446 »
I accounted for all squirters but one , it possibly got crushed in the # 2 cylinder
After spraywashing the case halfs with oven cleaner i ve come out with this, there is no other damage next to the rod smacking the inside of the case between the number 1 and 3 cyl
it s not too badd and should be no problem for the new engine
the real damage is at the head and of course in the cylinder wall which are both being replaced
N1446 Brutus
N1446
Post by N1446 »
heay all it s been a while since i post in this topic
here's a summer pic with updated wheels, the car's a bit dirty tho
in the backround is ceasar, the next engine donor; a '98 forester s
the EJ25D in the car now is getting stripped for the heads to add to the 22T block and also the crank will be used as well, so long as it's not damaged from its recent overheating episode
N1446 Brutus
Re: N1446's '91 Legacy SS, et tu Brute?
Always wondered how my Forester S wheels would look on my SS. Not bad.
N1446
Re: N1446's '91 Legacy SS/2.5GT
Post by N1446 »
oh my this site and car is addictive
i sold my car tonight. sobb. big sobb.
i wanna say thank you Josh for your knowledge and apt for sharing it first
and thank you everyone else its been a grand learning cuve.
sold my girl. got a carset for my babygirl. end of learning curve.
been a pleasure!
Mg-lastride
N1446 Brutus
You're welcome for the knowledge, and sorry to hear you had to sell your baby. You're always welcome to stay and hang out. :)
Looks like you had fun on the last drive though.
