Wideband Question
92legacyss
Wideband Question
Post by 92legacyss »
I have posted once before about o2 sensors, can anyone recomend a spacific brand or do you have a part number i can use to find a good one with. Thanks all
92 ss 5MT..TD04, 02' Wrx TMIC, XS power Atmos. BOV and Gripforce stage 2 w/ WRX OEM Flywheel, Equal length headder and catless uppipe. Open DP and soon tobe CBE, WRX struts and springs, MBC
SLODRIVE
Re: Wideband Question
Post by SLODRIVE »
Innovate Motorsports' wideband has always worked well for me. It also seems to have the most compatibility with aftermarket engine management, if that matters to you.
http://www.slodriveracing.com
-And more!
gijonas
Post by gijonas »
X2 save up and buy and LC-1
skid542
Post by skid542 »
I haven't installed it yet but I got the Zeitronix ZT-2 with the ZR2 display (digital display). It's nice because you can log a total of five channels if you want, including the O2, EGT, and three seperates. It also has an accessory that you can use to program the unit to trigger a relay dependant on if/then statements on the 5 inputs.
I've heard good things about it and I'm anxious to get it going. I've also heard good things about the Innovate systems as well.
Lee
92legacyss
SLODRIVE wrote:Innovate Motorsports' wideband has always worked well for me. It also seems to have the most compatibility with aftermarket engine management, if that matters to you.
The Innovate motorsports offer the LC1 with the bosch lsu4.2 is that what you are running? Are you running stand alone or something like that ?
SLODRIVE
Post by SLODRIVE »
I'm running the LC-1 with the G3 analog gauge. It's also wired into my AEM piggyback, but only for logging purposes.
-And more!
SubiePrice88
Post by SubiePrice88 »
Do you need EM to run a wideband?
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
skid542
Post by skid542 »
No. Most EM's like to have a wideband input into them. However, most wideband's are standalone systems and any car that's being tuned or tweak significantly should have one. You just buy the system and install it.
Lee
SubiePrice88
I see. I should get one. So the sensor is just ran all the time and is hooked up to a gauge?
*Sorry If Im stealing the thread, I should most likely do some searching*
-Jordan
biggreen96
Post by biggreen96 »
My sm-afr from PLX devices, is meh. The display freezes sometimes. It's AWESOME when you are full throttle hauling ass then look down and see 16.5, back off the throttle and lose your rythm. I heard the LC1 tells you when the sensor is kaput too.
skid542
Post by skid542 »
Jordan, you are correct. The sensor runs full time and outputs to a gauge/display in the cabin. The display/gauge options vary depending on make/model/manufacturer. Many of them have a narrowband output for your ECU but it is generally recommended to run it seperate from your stock O2 system.
Lee
SubiePrice88
Makes 100% sense now! I'll look into it more. Thanks!
-Jordan
BSOD2600
Post by BSOD2600 »
After reading various reviews of widebands online from car magazine, LC-1 is the best for accuracy/response. Most can't even detect with the wideband goes bad like the LC-1 either.
'11 WRX Limited
'94 TW | R.I.P.
92legacyss
This might sound foolish but how does the wideband tie into your ECU? Do you have to have both a narrowband and a wideband or does the wideband connect to you ECU through the factory wirring?
Most widebands have a narrow band O2 sensor output to go to the factory ECU. This allows you to put the wide band in the spot of the narrow band. If you want to put a second O2 bung on the exhaust, then you can have both wired in.
skid542
Post by skid542 »
Many of the widebands will have an output from the controller that simulates a narrowband signal. This you would connect to the factory wireing harness.
It should be noted though that there are very distinct mixed results. Also, you generally place your wideband a little further downstream of the stock location (due to overheating issues) so you aren't trying to shove two sensors in the same spot. This means there isn't neccesarily a reason to eliminate the stock one, unless you just want to for clarity/cleanliness.
Lee
