TPS resistance readings - is this bad?
Snorkus, filters, throttle bodies and intake manifolds.
macipusy
Post by macipusy »
I checked the Ohms on my TPS vs FSM and they are as follows:
No2-No3 - FSM 12 kOhms, TPS reading 9 kOhms
No2-No4 - closed - FSM 10-12 kOhms, TPS reading 8.56 kOhms
No2-No4 - open - FSM 3-5 kOhms, TPS reading 1.82 kOhms
What kind of issues would this cause. I've been having idle issues and stalling / no start issues.
Do I just adjust it, or replace it?
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
Re: TPS resistance readings - is this bad?
Those are close to the readings. The only thing you can or should adjust the TPS to is the idle closed switch.
http://www.main.experiencetherave.com/s ... sting3.jpg
macipusy
Post by macipusy »
Thanks for the tip....I checked it and it was within specs. I also doublechecked other TPS sensors on extra Tleg manifolds I had lying around, and they both were close to my original readings.
maciek puszynski
16 WRX | 6mt | fa20
Lunatech
Post by Lunatech »
While your at it maybe you could get a resistance reading from the IAC for me, THANKS.
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
yazmo
Post by yazmo »
Legacy777 wrote:Those are close to the readings. The only thing you can or should adjust the TPS to is the idle closed switch.
josh i try to do this but seriously is this possible without removing the throttlebody
there is no room to insert gauge and keep it straight,
BSOD2600
Post by BSOD2600 »
What type of gauge do you have? I was able to get it inserted to do the measurements
'11 WRX Limited
'94 TW | R.I.P.
yazmo
Post by yazmo »
how did you hold it? ill get a picture of me trying to place the gauge you will see what i am trying to say.
its like impossible lol
macipusy
Post by macipusy »
The gauge should stay by itself with the force of the TB plate springing back shut. You need to use the tiny feeler gauges.
maciek puszynski
16 WRX | 6mt | fa20
