help with wrx stereo in my legacy (again!)
Ok guys so i tried to merge the two bc/gc stereo harness's together and that didn't seem to work. So now i went ahead and bit the bullet and bought the metra reverse harness for the legacy and bought a metra impreza harness. I hooked up all the colors accordingly and then plugged two wrx stereos in and nothing happens. It doesn't turn on or anything. To make matters worse my interior dome lights dont work anymore either and i dont know why. If anyone has an idea on how to fix this please chime in.
2005 STi (500WHP with "SlowSTi" as the license plate lol (Weekend Warrior)
1991 Legacy ss JDM EJ20G swap with STi goodies (DD)
Re: help with wrx stereo in my legacy (again!)
You blew the fuse. Same fuse runs the cabin lighting and radio. I think it's in the engine compartment fusebox... Disconnect any red, yellow or red/yellow wiring you did before you replace it, unless you're sure everything's hooked up correctly.
Jerry
Thank you. It did end up being a fuse in the engine compartment.
