CLOSE
CLOSE
got it thanks!
Re: WTB ASAP! : Turbo lifter, Bypass valve
ihave an OEM bypass valve from my twin turbo motor, it's the same as turbo legacy if you're interested. however im not interested in the bosch bypass valve. 20 shipped?
Re: WTB ASAP! : Turbo rocker arm
I found a BPV locally, thanks though!
Post updated
Post updated
Turbo and N/A rockers should be the same.
N/A rockers are roller rockers and don't have the HLA's
99% sure only the 95 and up 2.2s had roller rockers. Not sure about the 1.8s. The 90-94 N/A 2.2 had the same rockers as the turbo.
'90 Legacy Wagon
STI drivetrain, T-Leg Engine,
68 Barracuda S Coupe
'90 Legacy Wagon
