Recommended rear camber plates for '03?
czei
Post by czei »
I purchased a '93 NA Legacy about six months ago, and its set up for rallycross, which means it was raised at least a couple of inches, if not more. The unfortunately side effect is that the rear wheels now appear to have at least a couple of degrees of positive camber. I tried installing camber bolts, and the rear wheels are still visibly (and measurably) leaning in.
My next step is to try camber plates, although they can be expensive. Are there any recommended models that will fit this car? My understanding is that anything '93-'01 Impreza RS should fit, but I can only find front camber plates, not rears.
Thanks for any tips or links to existing threads on the site.
skid542
Re: Recommended rear camber plates for '03?
Post by skid542 »
One of the best ways to adjust your rear camber will be to use the adjustable lateral links from Whiteline. They'll also let you upgrade your rear sway bar attachement style giving you a couple more options there for endlinks. They are a little pricey I guess but you get full adjustability.
Something to look into.
Out of curiousity, what kind of springs are you running that gave you the lift?
Lee
czei
Post by czei »
Thanks for the suggestion! I don't know for sure the origin of the springs, as the suspension had been modified when I bought it as a rallycross car. I was told they were STi springs, but when I took them off and compared the compression to RS and WRX springs they were much, much softer. The combination of tall, soft springs with STi struts works great on the extremely rough rallycross courses, but the strong positive camber can't be healping.
czei
Post by czei »
Do you think the white line KTA108s are the right lateral links?
skid542
Post by skid542 »
From what I'm seeing the KTA 108s are for 02+ WRX.
What you want is something that works for 93'-99' imprezza. GC chassis.
Lee
The KTA 108's are for the Wagon's, which will work for our cars.
I am using them on my car.
http://www.surrealmirage.com/subaru/ima ... links2.jpg
http://www.surrealmirage.com/subaru/ima ... links3.jpg
skid542
Post by skid542 »
Well, I guess that answers that. I'm sorry for the confusion.
Josh - thanks for clarifying that for me.
Lee
speedmaxx
Post by speedmaxx »
im running some adustable rear links off of ebay for a impreza 2.5 rs. they rule for the money, I only paid like $150ish for all 4 of them and they came with poly bushings. there holding up great for me and there way cheaper then the whiteline ones.
93 legacy l
to much to list....
czei
Post by czei »
speedmaxx wrote:im running some adustable rear links off of ebay for a impreza 2.5 rs. they rule for the money, I only paid like $150ish for all 4 of them and they came with poly bushings. there holding up great for me and there way cheaper then the whiteline ones.
Which eBAY rear links did you get?
