Make: Subaru
Model: Legacy Sport
VIN: JF1BC673XPG602883
Mileage: 206,000 and counting (daily driver)
Price: $1700
This is Member "SLOWHATCH's" old car.
I am selling my '93 Subaru Legacy Sport Sedan. This was the top model of the Legacy from 1991 to 1994. New tires with less than 600 miles on them. The sunroof is still in excellent working condition with NO LEAKS. The AC does not currently work. All power windows in good shape, power locks work. Interior is in good shape minus the front seats where somebody slashed the seat bottoms. Transmission shifts well and the clutch is good. PASSES EMISSIONS! It has an aftermarket muffler, but it's pretty quiet since it's still got all of the OEM exhaust back to the rear wheels. When I bought the car it had a bad valve tick and this has been repaired. I replaced the original busted motor mounts with STi Group N solid rubber mounts, and the shifter bushings were replaced with the Turn-in-Concepts bushings.
THE INSIDE OF THIS ENGINE IS IMMACULATE!! I was so surprised when I pulled the valve cover I nearly crapped.:goodjob:
The body has seen better days, but is not bad at all, just not very pretty either. The hood and right fender were replaced and have not yet been painted. The front bumper has the paint cracked off, but no bumper damage (you can see this in the 4th picture). There is a dent above the passenger door handle
I am asking $1700 AS IS.
NEW: Tires, MAF, knock sensor, Brake Master Cylinder, and Nelson Mandela air freshener.
contact @ 404-661-7147
-Parker
