Hello.
I have a 92 Legacy 20T.
And bought Haltech Platinum Sports 1000 But have a little trouble getting it mapped so everything works.
Does anyone have a Map that I can get, so I can start the car?
Sincerely,
Anders Bjellum Svenskerud
92 Legacy 20T Haltech
Re: 92 Legacy 20T Haltech
Hello Anders and welcome to the BBS.
Unfortunately, I don't have a map for you, but I might suggest you look and see if Haltech has any support type forums where other Haltech users may have a base map to start with.
My Link ECU came with a base MAP I modified for my Legacy. Does Haltech have any base MAPS you can use or modify?
Hey Josh.
Thanks for the reply:)
I downloaded the base MAP, but they have only 93 WRX. So I wonder a little if there is someone who has a MAP or a base that is modified. I only need one so I get the car to start.
But thanks for the tips and advice:)
Best Regards Anders Bjellum Svenskerud
Hi Anders,
You should be able to modify that 93 WRX MAP to work with your Legacy. Depending on how you have things wired up, you may need to modify things. Otherwise, the crank/cam trigger setup should be the same.
Hmm. Ok. Thanks again. I'll try.
Everything seemed a little while, you see, but now suddenly it seems not.
But I tried a little forward, and if I just change the values, credits, they showed quite something else.
