Most random thing ive ever seen
Justins91ss
Post by Justins91ss »
On my way back up to seattle from las vegas last night, put gas in the car and turned it on the speedomotor/odomotor both randomly stopped working? Any thoughts/reasons as to why? Thx in advance
SLODRIVE
Re: Most random thing ive ever seen
Post by SLODRIVE »
I'm guessing bad/disconnected speedometer cable. Maybe something came apart during your trip.
http://www.slodriveracing.com
-And more!
Justins91ss
Yea very true it was just random is all, now the check engine light comes on and off also, have to get that issue addressed next just one thing after another ugh
Jessekrs123
Post by Jessekrs123 »
Well if you own a 1st generation legacy, then the speedometer and odometer is ran by a mechanical cable. If you pop the gauge cluster out you will know what I am talking about. It is possible that it might have gotten loose and popped out. If it did pop out, just line things up, and you can snap it back in (you will hear the snap). Then before you reassemble your interior MAKE SURE that it is working so you do not have to take it all apart if it doesn't. You can also diagnose your CEL with the on-board diagnostic wires and see what your car is having problems with and fix that too.
2015 Subaru BRZ
1993 Subaru Legacy Sedan 5 Speed FWD Green (EG33 swap in progress)
1984 Subaru BRAT Tan
Unless the gauge cluster has been removed before I doubt it popped off. It is very hard to snap on and doesn't come off very easily either. What probably happened is some part of the cable or the piece that inserts into the transmission snapped. The check engine light is coming on because you're driving the car without the speed sensor hooked up (it can't read speed without the speedo cable turning in the gauge cluster). I did that 2 weeks ago and it caused all kinds of problems and the check engine light was flashing. Hooked my speedo cable up and all was fine again.
Justins91ss
Hmm i see, yea i dont know much mechanically with these cars as i havent had much time to look/work on it..hey kimo i got a job for ya lol :) lemme know how much $ ya want. Thx
Is the car an auto or manual trans?
Justins91ss
Auto.. :)
gijonas
Post by gijonas »
Your life is ridiculously sheltered if that is the most random thing you've seen.
Justins91ss
Car wise yea.. Just dident make sense how when i parked it to get gas it worked fine, start the car again 5 minutes later and it dosent work same with the odomoter. And my life is far from sheltered
You likely need a new one of these.
http://main.experiencetherave.com/subar ... lebase.jpg
It screws into the transmission. and is pretty easy to replace.
Justins91ss
Thank you josh i appreaciate the help!
