Going to be putting in a new clutch
Mattheww044
Post by Mattheww044 »
OK guys, i got a few questions for you, and need some advice.
1. I need to swap my clutch ASAP. I was told by a few people that 02-05 wrx clutches will work.
I wasn't sure if I should go with a stage 1 f1 clutch kit for a wrx off of ebay, or buy the oem Exedy clutch replacement kit. Price is about the same (250ish).
I was also wondering if it would be worth the money to buy an aftermarket LW flywheel, if so, what do you guys recommend (is it ok to mix lw flywheel + lw pulley?)
And lastly, when I am swapping my clutch, I will be pulling the motor. I am also going to replace the motor and possibly trans. mounts, valve cover gaskets/grommets, and rear main seal. Is there anything else you guys would recommend replacing while I have the motor out?
Thanks for the help!
Matt
Re: Going to be putting in a new clutch
Matt,
Did you end up doing this work yet? Did you get my PM?
I'd go with the Exedy and the LW flywheel is kind of a preference. It does help engine acceleration, but can make the car a little more demanding in terms of concentration to drive it smoothly.
