stupid trouble codes part 2
lucas
Post by lucas »
so previously i posted this "been getting a random check engine light that makes the car stumble pretty bad when taking off from a stop checked the codes and its a 23,35,45. any ideas?"
well i changed the MAF and few days go by and its good just 20 mins ago i warmed my car up and went to PIA to get a clutch quote then pulled outta there and headed back for mcchord AFB on the way i stopped and jack in the box all was good still. Upon leaving the drive thru the light comes on and same BS with the stumbling and what not. im stumped maybe a knock sensor? purge control solenoid? both are a year old.... so idk
1993 legacy ss "Shela"
Re: stupid trouble codes part 2
well, you definately don't have to worry about the code 35.
for the 23, try using some maf cleaner. is your cone filter real close to your maf? Often times with the amount of air entering the filter (or for turbo cars, being sucked in even faster) the oils from the filter get on the maf.
for the 45, try to find a new pressure sensor and see if that helps any
lucas
Post by lucas »
where the heck is the pressure sensor?
lucas
Post by lucas »
i found it nvm
gijonas
Post by gijonas »
MAF's suck and are very common problem causers.
lucas
Post by lucas »
still getting a code 23 and 45
did you clean your maf? try resetting your ecu
lucas
Post by lucas »
ill clean the maf and ive just reset the ecu well see what happens
