auxiliary input
mreks
auxiliary input
Post by mreks »
Anyone know of a way to wire up an auxiliary input to my stock 93 legacy tape/radio, so I can connect an iPod without the cassette adapter?
If not, any advice on a relatively cheap unit, with an aux/in to replace the factory unit with minimum hassle?
thanks,
e
HomeSlice
Post by HomeSlice »
on some of the radios in the 90-94s had a aux in the front if you dont have that i supose you could get sum fm mod.
93BC"edm" 93GC 90BC R.I.P.
THAWA
Post by THAWA »
yeah go search the junk yards for a stock radio, some have it som don't :\
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Post by entirelyturbo »
Pssst, mreks, I have two stock radios in my closet, I'll sell ya one for $25 ;)
*Formerly DerFahrer*
Guys!! I posted about this a long time ago. Look at my web site:
http://www.graphics.cornell.edu/~v/bcstereo/
I have a stock 93 BC stereo in my girlfriend's Mazda 626 with a wire coming out the side for her MP3 player.
georryan
Post by georryan »
vrg3, I just looked at your sight, and....<laughing> I can't belive you programmed an assembly program to run your super NES controller through your computer. How old were you when you did that?? In college, or have you been into assembly since high school?
I'm impressed.
-Ryan
PS - sorry to jack the thread, that wasn't the intent.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
mreks
diagram
Post by mreks »
well, thanks vrg3, that looks like it would be very helful to someone who understands electronics better than I :) Any chance of simple instructions how to rig an aux input to that DIN connector you show?
Ryan - That was in high school... My "ultra old-sk00l" page was from 10th or 11th grade; can't remember now. That email address doesn't even work anymore. The page is there for posterity's sake mostly. I got into x86 assembly in 8th grade when I started democoding. Now I'm actually using it again for the Select Monitor hacking I'm doing. :)
mreks - I assume the iPod has a 3.5mm jack on it (like for headphones)?
If so, what you need is a 3.5mm stereo plug:
And a 13-pin DIN connector that fits the jack on the back of the stereo, and a switch that you can fit somewhere on your dash.
Wire one side of the switch to an accessory +12v line (like your cigarette lighter or pin 1 of the radio's 7-pin connector) and the other side to the "TRG" pin of the DIN connector. Then wire the "ground" contact of the 3.5mm connector to the "COM" pin of the DIN connector, and the "R" and "L" contacts to their respective counterparts.
You can then find a place to run the cord with the 3.5mm connector at the end out through the dash. In my girlfriend's car I just had it come out beside the stereo. It's a little pinched but it's not too bad.
Then, when you hit the switch, the head unit should go into "external input" mode and amplify the sound coming through that jack.
Let me note (I should add this to that page too) that I did this reverse-engineering on a Panasonic head unit, and so it's possible that it's different for Clarion radios.
georryan
Post by georryan »
Your a maniac vrg3! In a good way, but holy cow. Props to ya man.
2014 Volvo S60 T5
Heh, thanks... I need to work hard to stay worthy of subyluvr2212's praise. :)
ultrasonic
Post by ultrasonic »
I know, I know. Thread from the dead.
Vikash's images are gone--
did anyone happen to document the pinout of the OEM head unit/CD link? I'm sure I can poke around and get it to work, but if someone grabbed his diagram it would be faster.
Thanks.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
ultrasonic
Now that Vikash is lurking again... bump.
-steve-
03 Legacy L Wagon
Try this:
http://www.surrealmirage.com/vrg3/bcstereo/
Let me know whether it works for you.
ultrasonic
Perfect. Thanks. I remember seeing years ago, but I didn't have a use for it back then.
-steve-
03 Legacy L Wagon
No problem. Hopefully with time we can restore most of the useful information I used to have up on the web.
So, I can I wire in the aux to the DIN in the back AND the stock CD player?
Another option, can I get a newer CD deck that hooks up to the DIN that can play MP3 RW disc.
I don't know if you can wire two sources in at the same time. I guess it depends on how their output stage circuits work. It's probably safer not to.
You can connect any newer CD deck to the stock deck's DIN connector as long as it has line-level outputs. Or even if it doesn't, you could use a line-level converter or something. You'd lose some sound quality but running through the stock head unit isn't gonna get you great sound anyway.
Why do you want to keep the stock head unit? For the tape player? Cuz you might be better off using a line level converter to connect the stock head unit to an aftermarket head unit's aux in instead of the other way around. I did that before.
i dont mind the stock head unit sounds good enough for me. More input options would be nice. Ill look around for a cd deck instead i think.
