your top hats are the same as outbacks
it will bolt on, if your axles are already on the way out, the lift will amplify any issues, otherwise your good to go
legacy lift
Re: legacy lift
awesome! thank you now i know that to get, shoud, it make a difference if i just do the struts? or should i do all of it? i believe my cv's should be fine... they seem to have no stress right now.
1995 subaru legacy ls few mods,
Re: legacy lift
Just go with the struts. Itd be cheaper, but thats just my opinion.
90 2.2 N/A legacy awd wagon with outback struts.
Re: legacy lift
thats what i was thinking of doing just the struts all the way around, because then its not to much wear on my CV's, and its cheaper, and it will still lift my car up a inch or so?? wont it? but the 98 struts for an OB will bolt up to my 95 springs and mounts? easy right?
