92 idle miss
turbo5711
92 idle miss
Post by turbo5711 »
I have a 90 legacy with a 92 motor n/a in it I have a miss at idle but runs good above 2000 rpm. I have checked all the sensors i have tried changing the plugs wires and even the injectors it is only happening on the passgeer side head but i am at wits end with it
wtdash
Re: 92 idle miss
Post by wtdash »
Compression test?
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
jefferson
Re: 92 idle miss
Post by jefferson »
That was my thought too.
turbo5711
Re: 92 idle miss
Post by turbo5711 »
ok thanks ill try that test on it next
SiCkSTi04
Re: 92 idle miss
Post by SiCkSTi04 »
Is this an engine swap with the misfire results? or did you get the car this way. reason I ask if you swapped over the injectors as they are different. Also try doing an ohms test on the injectors, coil pack and spark plug wares. And if you're getting any trouble codes.
turbo5711
Re: 92 idle miss
Post by turbo5711 »
it started after i had a timing belt slip it is 1 cyl not firing at all i am worried it is bent valve got i hope not ill check compression soon
wtdash
Re: 92 idle miss
Post by wtdash »
The EJ22 was non-interference 'til '96-ish, so shouldn't have bent a valve, but are you 100% sure you have the T-belt on correctly? One tooth off or using the wrong mark on the Crank sprocket will cause similar issues.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
turbo5711
Re: 92 idle miss
Post by turbo5711 »
humm thanks for info ill check it tommorw
turbo5711
Re: 92 idle miss
Post by turbo5711 »
well thanks for the info it was the timing it was a tooth off on passenger head all fixed runing very good now
SiCkSTi04
Re: 92 idle miss
Post by SiCkSTi04 »
Awesome to hear! Cheers!
