Old Plugs 1-2-3-4
Ummmmm.... I went to see about injectors and a BOV, I just bought this.... Oops
93legacylsleeper wrote:The Smog was the worst i've ever had to pass... they got me for The MBC, BOV, and a broken elbow on the charcoal canister. That was on top of the header, up-pipe and non-stock turbo. I had to go completely back to stock. Sweet that you racing, post the times as they get lower with the new parts.
the only Subaru i have touch was the 2002 WRX, so all my knowledge comes from thisApex3 wrote:Make sure you're keeping track of what fits and what modifications are needed to make things fit. Neither of those exhausts are direct bolt on, you'll have to do some extending. Lot's of things swap over, but it's not a WRX, so not everything will work, plus the differences between years.
95% of WRX parts will work, you just seem to be moving really fast, so I'm just warning you that some don't, and some need to be modified.darkcrave wrote:the only Subaru i have touch was the 2002 WRX, so all my knowledge comes from thisApex3 wrote:Make sure you're keeping track of what fits and what modifications are needed to make things fit. Neither of those exhausts are direct bolt on, you'll have to do some extending. Lot's of things swap over, but it's not a WRX, so not everything will work, plus the differences between years.
Im not sure what im missing:
I know the downpipe will bolt up to the turbo, may not fit the trans mount
I know the STI fuel injectors need the NA fuel rails?
I know im going to have to extend the cat-back a few inches
i know i have to cut the y pipe and extend that to make it work with the wrx intercooler
Im not 100% sure how to make the WRX linkage work ( ehhhh)
if im missing anything please let me know im trying to get everything correct before i even touch the car!
The downpipe will have to be extended as well, and most have the o2 bung at the bottom, needs to be at the top or the wiring needs to be extended, looks like yours is kinda in the middle so I don't know what you'll need to do with it. The rest of the stuff I'm not really sure.
Like I said though, just telling you to be careful with what you're buying.
Have you given any thought to suspension or brakes? They kinda go along with the added power usually...
Ill take it if you have the JDM jecsFlorin1 wrote:I got a spare MAF you can have cheap. The DP should be direct bolt on, dont see why it would need extending.
Really? I was under the impression they're too short, maybe I'm wrong.Florin1 wrote:I got a spare MAF you can have cheap. The DP should be direct bolt on, dont see why it would need extending.
