2005 Legacy GT flywheel in an SS?
I'm wondering if an aftermarket lightweight flywheel for a 2005 Legacy GT (push style tranny) will work in an SS with a 2002-2005 WRX clutch kit?
Florin1
Re: 2005 Legacy GT flywheel in an SS?
Post by Florin1 »
Edited. Figured since it was ej series motor... What do i know, i usually shoot first ask later. :(
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
Florin, is there a reason you'd say yes to interchangability between a puch and pull style trans?
Post by entirelyturbo »
Fairly certain they are not interchangeable. Also, the 05-06 Legacy had a dual-mass flywheel, while 07+ went back to the single-mass, and from an experience at work, those only interchange with the right flywheel bolts.
Sent from my HTC Droid Incredible using Tapatalk
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
I posted the question on Nasioc as well, and someone said that the pull type have a "stepped" flywheel, which won't allow the clutch kit to be bolted flush to it. Ah well, it was worth a try.
