Engine Head Rebuild Parts List?
Baddog
Post by Baddog »
Hey there,
I have stopped by this site quite a few times. I was told about this site by Douglas Vincent "Reddevil"
He is rather busy and haven't been able to get a hold of him.
I am going to rebuild my EJ22 on my 96 Legacy L. I was going to have the heads rebuilt was curious of a parts list.
Valve Guides
Exhaust Valves
Intake Valves
Head Bolts (?)
I know I am missing quite a bit of things.
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
brand
Re: Engine Head Rebuild Parts List?
Post by brand »
It's probably going to be a lot easier and way cheaper to find some decent used heads and slap those on, unless you have a specific thing in mind like oversized valves , or you have some donor heads for parts already.
91 SS with a bunch of parts waiting on the shelf
94 SS with things and such
08 STI with stuff and junk
The valve guides and valves are probably going to be ok. You should have them checked, and have the valves ground & lapped by a machine shop. You should replace the valve seals though.
Personally, I would take the heads to a machine shop that knows Subarus and have them do a valve job on the heads. That will be most of the tedious work with the valves, and then you just need to reinstall them.
