Have a 2011 Legacy and need help on where to begin to removing factory radio. Can someone please tell me where begin? I know how to install, just can not figure out where to remove the plastic HVAC housing.
thank you
2011 Legacy Radio Removal
Re: 2011 Legacy Radio Removal
This forum is for 1989 to 1994 legacies. You'll get better results on nasioc, etc.
'11 WRX Limited
'94 TW | R.I.P.
you need to detach the cables from the heater assembly
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
check out http://www.legacygt.com
this should help
http://legacygt.com/forums/showthread.p ... io+removal
this should help
