rear diff help
mazda ej22t
rear diff help
Post by mazda ej22t »
hey guys i have a 92 leggy turbo automatic. i bought a 99 wrx type ra close ratio tranny that has a 4.44 viscous diff. That means i need a 4.44 rear diff right. for those who has done a 4.44 swap do i need rear axles too or will our stock axles work with 4.44 rear diffs?
ive been researching a few sites but i cant find anything about our leggys thanks guys appreciate the help
Re: rear diff help
I'm pretty sure the 4.444 diff uses male axles meaning the diff does not have axle stubs like the 1st gen legacy's have so yes you would need the axles that go with the 4.444 diff.
mazda ej22t
Re: rear diff help
what about the length as well. are all the axles the same length or will i need certain model axles for the diff
n2x4
Re: rear diff help
Post by n2x4 »
mazda ej22t wrote:what about the length as well. are all the axles the same length or will i need certain model axles for the diff
The rear axles will be the same length. Subaru started using longer axles in the WRX sedan starting in 2002. You'll be fine with the older stuff.
Easiest way to source a 4.44 diff will be from an automatic Subaru Forester. You can swap the entire diff or just the ring and pinion.
SUBARUEHS Racing
Re: rear diff help
Or outback.
mazda ej22t
Re: rear diff help
cool i found a 99 legacy outback diff and axles. p.s. how come i cant make a build journal? you guys would like it. im putting an ej22t engine, wrx ra tranny and the irs into my mazda truck
Re: rear diff help
You need to be added to the build journals group. If you would like to start a build journal, send me a pm.
mazda ej22t
Re: rear diff help
guy rotated the driveshaft says the gear rotated 4.33 times....means its 4.44 then? or is that 4.11?
