Header Fitment questions
Baddog
Post by Baddog »
I have seen a few threads about Header fitment and how a shop will have to weld up a new pipe for the cat section. What options are there for headers?
If I took these into a shop would they be able to make them work?
http://www.speedyracer.com/servlet/the- ... for/Detail
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
Re: Header Fitment questions
I'm assuming this is for a non-turbo car.
There isn't any stock headers that will fit without modification of cat section.
Baddog
Post by Baddog »
Yeah, it's for a 92. Has anyone had this done and know the rough cost to have the shop install the headers and redo the piping to make them work?
white91wagon
Post by white91wagon »
Its going to cost quite a bit to fab up something for those ones. I run theses ones on my 91 legacy and have had good luck with them so far. Good sound, some fitting issues, but great for the price. They are a direct fit which will cut down on cost. Also give a great deal more flow over stock. If you peel away all the shielding the stock manifolds are pretty constrictive IMO. Especially at the small Y right out off the head flange.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 818wt_1002
Also if you want to go a little wild these are so sweet! Wish i had got them instead :roll:
http://www.subarugeneration.com/OBX-EXH ... header.htm
Baddog
Post by Baddog »
Those are equal length how do they sound?
And it would really cost that much to use the UEL's that I posted?
TurnNburn
Post by TurnNburn »
Those headers look wierd to me. Is that a mirror image or does the exhaust go out the opposite side on NA cars versus our turbos?
1990 NA 2.2 Open Light rally car
Baddog
Post by Baddog »
The ones I posted? Or the Magnaflow ones?
The other ones are built for the Dual Port EJ22's and EJ25's on the 2nd Gen Legacy. Our cat placement is different then the first gens.
I was wondering what could be done. She wants sound and no EL headers.
TurnNburn
Post by TurnNburn »
yeah i meant the ones in your original post. Iv never seen a set up like that, but then again i dont have any experience with other gens of legacy.
Baddog
Post by Baddog »
Any other options for UEL? Or any at all?
dullers
Post by dullers »
if you brought in the header, cat, muffler
i would expect to spend ~200$ to have a shop fab the rest.
UEL you can go with aftermarket EJ25 headers but you'll need to buy the cat + have them customize the rest
92 Legacy L, AWD Auto. 94k miles purchased in May 2011 for 250 bone$
It starts...
Baddog
Post by Baddog »
Just doesnt seem reasonable to get a full headerback on these cars.
WRXish
Post by WRXish »
I would very much like to have an equal length header and free flowing cat to go with the custom cat back I had put on a while back. I have no doubt it would wake it up a bit. What works on a 91 2.2?
WRXish wrote:I would very much like to have an equal length header and free flowing cat to go with the custom cat back I had put on a while back. I have no doubt it would wake it up a bit. What works on a 91 2.2?
Yeah a later aftermarket dual port header with a fabbed up cat section would work. What they're saying above is there's no header that bolts to our factory cats.
