Replacing lateral link. WRX, Wagon OR GC8??
253.Asmo
Post by 253.Asmo »
Ditto. Which years match the geometry and size of our cars? Looking to replace them with Godspeed units, thanks!
Matt
'94 White SS / 5MT - daily, absolute piece of a beater
'90 Red Sedan - EJ22T / 5mt Swap - drove it, SOLD it
'91 black SS / 5MT - (215/230k miles. eng/body)
[RIP - drove, hit, cracked a piston, swapped and stripped for swap again]
Re: Replacing lateral link. WRX, Wagon OR GC8??
GC8 for sure is right, don't know for sure about the GD's.
253.Asmo
Post by 253.Asmo »
Picked up a set for the wrx, we'll see. If it doesnt work, then GC8 stuff all around should do the trick.
Matt
WRX wagon links will work fine.
TurnNburn
Post by TurnNburn »
Dont the WRX wagons have a slightly wider stance? Like 3mm on each side or something so they will bolt up fine but will have a small affect on alighnment ie. camber? Someones build thread i read a while ago said they had some that made thier car wider? Of course i cant remember who so i cant double check, but i was just throwing that out there.
1990 NA 2.2 Open Light rally car
The WRX sedan has a wider stance. The wagons are the same as our cars. I'm runing a set of Whiteline adjustable lat links for the WRX wagon on my car.
Scroll down a little bit and you'll see the ones I've got.
http://www.surrealmirage.com/subaru/swa ... suspension
