found some parts and was wondering if they'd fit
samurai
Post by samurai »
was browsing around for some engine parts when i came across some parts for a 98 subaru legacy outback 2.5
they are these:
intake manifold with throttle body and injectors
was wondering if they'd fit my 92 na with just bolting on or would it take more work? also they have the ecm-pcm-computer would i need that or would changing mine to that one prove to be better?
PhyrraM
Re: found some parts and was wondering if they'd fit
Post by PhyrraM »
They will not fit. Nor would there be an advantage to them.
If you also upgraded to the same cars DOHC heads, then they would both fit and be considered an upgrade.
samurai
Post by samurai »
ahh thanks for the info
