972.5 into a 91Legacy
tigardace
Post by tigardace »
Hey all I am new to this site and wanted to get outlook on this idea and see how hard it will be to do.
I am getting a 1997 Legacy gt with 2.5 rs engine I am wanting to swap it out for my 91 2.2 engine any ideas? :D
Re: 972.5 into a 91Legacy
Welcome to the BBS.
Just to make sure I am understanding you correctly, you want to take the engine from your 91 and put it into your 97. The big issue you'll run into is the fact the 97 is OBD2 and has a different engine management setup than the 91 which is OBD1. I do not believe all the sensors are the same between engines and you will likely have issues getting the 97 ECU to work without a CEL. Assuming you have a state inspection, any CEL's will keep you from passing.
tigardace
Post by tigardace »
Lol. No I want to take the engine out of the 97 and put it in my 91. It is a 2.5 and newer and less miles. Plus 30 extra hp
Falken-18c
Post by Falken-18c »
i guess your 2.2 is an na
hitzkrieg
Post by hitzkrieg »
the early EJ25 dohc motors are notorious for failing head gaskets. In my opinion, you're better off not swapping the engine from the 97 into the 91. It's not very simple and will probably cause you a ton of headaches.
- 94 Touring Wagon, Quicksilver Metallic 95k miles
It'll physically fit I believe, but you'll run into issues with the wiring and would likely need to rewire things and need to use the original 2.5 ECU.
Its been done before. I believe the 2.5 cam/crank sensors work with the stock ECU. Something needs to be done to fit the EJ22 throttle body to the EJ25 manifold. Search the engine section, its in there, somewhere.
