So it begins....
Picked up a Invidia Downpipe and a Magnaflow metal highflow cat
Built a jig to hold it and cut it apart to put the cat in and add o2 bungs
Next came brakes
Then I found a melted plug on the heahlight harness while I was replacing the battery
Picked up some Impreza RS seats for a good price to replace my old and torn seats
Came across these for $150 brand new so I couldn't pass them up, H&R legacy springs
Got my wheels powder coated
Replaced the rest of my exhaust with a Blitz Nur Spec system I found on ebay from a jdm twin turbo second gen legacy wagon. Sounds so nice
Now the big work has begun, I was having a problem with loud tapping/banging sounds coming out of the bell housing and the tranny acting funny so Ericem and myself pulled the motor and tranny out.
Here is Ericem happy that the motor is free
Found the cause of all the banging sounds....
Now that the motor is out its time to fix that up and that's as far as I have gotten thus far. Going to replace the timing belt, water pump, spark plugs, wires, cam seals, reseal the oil pump, send the cams off to delta cams for a regrind, replace the valve cover gaskets, new knock sensor, paint the valve covers wrinkle black and the intake wrinkle red, replace the rotted out exhaust manifold and finally install the new tranny
