ABS Light
Tommio RS
ABS Light
Post by Tommio RS »
Hi there. I was wondering how to read the abs light codes for my 94 legacy ss.
I have tried these places on info on how to do it and failed... The connectors are never there....
http://bbs.legacycentral.org/viewtopic. ... ht#p352240
Help??
Thanks!
93 Legacy Turbo AT Sliver Stock, Ultra Rotty Body
93 Legacy Turbo MT Silver Rob Tune 550cc Lowered GT28 AWIC 4.11 05 Leg GT rims Mint body
95 Chevy Corvette MT ZR-1 Black X Brace Chipped
94 Legacy Turbo AT Blue Stock SOLD
06 Pontiac G6 AT Green Stock SOLD
Re: ABS Light
The connectors are definitely very difficult to find, but they are there. If you can't find the connectors, the other option would be to use the Subaru select monitor (diagnostic reader) to pull the codes from the ABS computer. You'd have to go to the Subaru dealer.
I have also been told or heard that there is a small green LED light you can see on the ABS computer under the passenger seat. There's a little flap of carpet that can be flipped up to see the light. This may be on the 90-91 MY's, but may not be on the 92-94's. You'll just have to check and see if it's there.
Tommio RS
Re: ABS Light
Post by Tommio RS »
Thanks Legacy777!
Tho the green light on the abs computer is not on my car... mines a 94....
But on the flip side i did figure it out how to get the codes out of the ABS computer!
There is a white male connector that is under the drivers kick panel. You just need to ground out a pin and you do the light dance for your codes.
So i have a faulty LF sensor.
Re: ABS Light
Good deal. Now you just need to get that sensor out :)
SUBYLUV871
Re: ABS Light
Post by SUBYLUV871 »
I have the same issue. i did a front axle, now my light is on. ill check the sensor the see if i damaged it at all.
1998 legacy l wagon
1988 ford ranger prerunner (my baby
