TD05 Kit
				Thesubielover
TD05 Kit
Will this full set up work for our 1st gen tlegs?  I know I'll probably need fuel injectors, and a new fuel pump.  Anything else?
Thanks for ther help.
				Thesubielover
Re: TD05 Kit
				Thesubielover
Re: TD05 Kit
I guess I'll have to do some different y pipes or something like that from what I see on here
				BoostedSubie
Re: TD05 Kit
I wouldn't go with the td05-20g, you'll be dissapointed with the lag. If you want a bigger turbo, I'd go with the td05-16g. You should look into the Robtune to go with the turbo, 550cc injectors. Its a good bump in power without spending a ton of money.
							93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
99 Black Legacy GT wagon
						93 Legacy
97 Green Outback
97 Red Legacy GT
Re: TD05 Kit
That kit also looks like it's meant for a GD WRX throttlebody location. Gonna be real tight on the firewall with an SS. Likely have to get creative with the y-pipes and such.
Re: TD05 Kit
i wouldnt put an ebay turbo on my car, unless it was a real brand that the guy was just selling on ebay. i know wayyyyyyyyyyyyyyyyyyyyyyyyy to many people that have had them blow up in 500 miles. the rest looks fine though. i agree go 16g.
							92 turbo legacy: RWD W58 SWAP,  td04, 3"tbe, mbc, fmic, wrx brakes/hubs, wrx seats, welded 4.11, fcd, drift steering wheel, Drifting Stickers
				Mister Anderson
Re: TD05 Kit
91 black SS 5 speed (Canadian).... Closed deck EJ20G, fully built, V5/6 sti ra drivetrain, haltech stand-alone
93 silver TW 5 speed... rebuilt 22T with 20G heads, wrx ra drivetrain, otherwise stock.
73 kazen red VW bus riviera camper
Re: TD05 Kit
The TD05-16G is great. I have one on my car with a WRX intercooler and I see full spool of 18psi around 2600-2700 RPM and holds to redline no problem.
				Thesubielover
Re: TD05 Kit
Are you running stock intrnals?  Probably at least fuel rails and injectors.  I'll see you at the dyno day man!
Re: TD05 Kit
I have injectors and a Revtronix tune and the intercooler and a 3" exhaust. Still on stock heads, cams, intake and internals.
				Thesubielover
Re: TD05 Kit
Im in the middle on installing m 3in dp, 3in cat back, mbc, boost gauge, and wide band gauge.  Next is coilovers, wheels and tires, brakes and maybe clutch.  The finally injectors, turbo, rob tune, tmic or fmic.  My seats are the tleg leather ones and they are still like new.
Re: TD05 Kit
It would be cool to see some pictures of your car posted up here.
Also as far as I am aware, there has never been a T-Leg that has had leather seats from the factory. I bet yours have been swapped from a different car. Still cool to have them. Do your door panels have a leather insert too?
				Thesubielover
Re: TD05 Kit
Yeah the entire interior is leather, with a soft touch leather dash and door panels.  They seem pretty factory to me.  They have the lever to raise and lower the driver seat, plus a lumbar support wheel.  The back seats are leather too, with a leather arm rest in the middle.  I need to find my camera, but I'll try to get pics up soon.  I was going over your thread and yours looks pretty clean too man. I love these cars.  I guess there is pro's and con's to having other people not know what they are.  One pro is hopefully no one will try to jack my shit here in seattle.
Re: TD05 Kit
that sounds exactly like my wrx seats i have in my car to the "T"
				Thesubielover
Re: TD05 Kit
There is a sticker on the window like he went to a shop and had everything done in soft trim leather.  I need to find my camera and I'll upload photos for you.  I don't think he would have changed the back seats too.  Do you have pics of your wrx's interior x2hawt4ux
Re: TD05 Kit
ya ill upload some pics.
Re: TD05 Kit
It's a really nice car.  I saw it last week and it's extremely clean and kept up really well.  I was impressed and jealous at the same time.
Re: TD05 Kit
Damn! That's super low RPM for 18psi. I think mine is more like 3,400 RPM @18psi. TD05-18g.Alphius wrote:The TD05-16G is great. I have one on my car with a WRX intercooler and I see full spool of 18psi around 2600-2700 RPM and holds to redline no problem.
Re: TD05 Kit
Yeah, it definitely hits hard and fast. If I floor it in first I get a little wheel spin when the boost hits and the front gets light all at once. Redline arrives in the blink of an eye and bounces the rev limiter if you are not careful. I always try to avoid boosting in first since it's so violent I think I'll break something. Lol. I'm very happy with the spool on a 16G.
Re: TD05 Kit
That's cool.  Mine does not break the tires loose at all unless I turn the wheels and then it's happy to get a little crazy.  I think my car is a bit lacking though.  Need different block.
Re: TD05 Kit
Yeah, I got a half point of compression on you Kimo (or more?), not to mention the crappy flowing EJ22T heads I have which push the torque peak way down, so although I bet I could best you on low-end torque (and tire spinning/transmission breaking
), you would probably have me easily on top-end HP. I start to run out of power by 6k and need to shift back down into the power peak. IF we end up having a dyno day up here and our cars both run it will be interesting to see the results with such a similar turbo and exhaust setup, but different goals for where the power is generated dictated by the block and heads.
Thesubielover,
It sounds like the original owner probably wanted an SS with leather and of course couldn't get one, so went to a shop and got a very expensive leather conversion done. As far as the back seats, it would be a stylistic abomination to have the fronts leather and the rears cloth, especially on a fairly new car at the time (I'm assuming), so I can see why those were done too. It's cool that the door panels and everything were done as well. That must be a nice car, and low mileage too!
						Thesubielover,
				Thesubielover
Re: TD05 Kit
Thanks Alphius and Kimo.  Yeah I bought it from the original owner in Bellevue WA.  He only had 113k original miles on it when I picked it up.  That means this guy couldn't of been driving more then 5800 miles a year on the car, which is pretty sweet.  Everything works like new.  The driver one touch power window, radio, power antenna.  The truck and all interior in general looks new.  There isn't a dent or rust anywhere, the steering wheel is OEM and doesn't have wear signs at all.  Kimo I was wondering, that box I have that you have been looking for.  The charcoal box (black).  Why mine has three hoses and your had two.  Most of the ones I have seen online have two.
Re: TD05 Kit
The three hose charcoal canister is a turbo leg specific piece. The N/A cars had a two port.
What color is your 93?
				Thesubielover
Re: TD05 Kit
Silver with black interior, are you going to the dyno day?  I should have my catback mailed to me sometime within the next few days.  Then to the shop for 3in turbo back
.  In april I'll be getting the mbc and gauges on.  Pretty excited. I like the camaro  man.  I have a 1972 chevy c/20 that I got when I was 15 for my birthday.  Since I've gotten it, Ive installed a new crate 350/350 and re build the tranny.  For some reason I'm just in love with subies now, especially when its snowing.
				Thesubielover
Re: TD05 Kit
Here is a link to a guy's thread on here who claims to have the same seats as I do.  Mine look 95% better though.  I've done some quick reading and it doesn't seem like it was a stock option.  So some owners must of had this done.  I'm going to try to get some pictures.  My girlfriends camera is dead and she cant seem to find the cord for it.
http://bbs.legacycentral.org/viewtopic.php?f=15&t=48205
