Just putting a feeler out for those who bought the lights.
Do you have them up and running?
Do you need a harness?
D
Bought an EDM headlight+levelers? What ya doing for harness?
dscoobydoo
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
Re: Bought an EDM headlight+levelers? What ya doing for harn
I have the lights but no harness yet.
04-05 STi headlight motors use the same connector so you can get the harness side from that, you will probably have to cut the wiring off the switch and make your own there though as nothing in the US I've found uses the same connector there.
Here's wiring data:
http://www.main.experiencetherave.com/s ... agrams.pdf
Here's wiring data:
I'll just go down to picknpull and grab a couple STI connectors lol. But seriously where do you get em from?Alphius wrote:I have the lights but no harness yet.
Here's wiring data:
I just used some generic connectors for that bulb type from Autozone...it's a standard part and most likely in stock. If you decide to go this route and need help figuring out the wiring, let me know.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
dscoobydoo
mike-tracy wrote:I'll just go down to picknpull and grab a couple STI connectors lol. But seriously where do you get em from?Alphius wrote:I have the lights but no harness yet.
Here's wiring data:
You have to get lucky and find someone parting out an 04-05 STI on Nabisco.
I searched the junkyards. 04-05 STIs are pretty rare in junkyards. WRX's are plenty.
05 GD-STI
00- GF
05 GD-STI
00- GF
Yeah, either look for someone parting an 04-05 on Nasioc and convince them to hack up their valuable leveler harness, or cut your plugs off and replace them with some Weatherpack connectors or something of that sort.
Yeah....if you can't find the stock connectors, try depinning the stock connector and use another weatherproof connector. If you're lucky, you may be able to just depin them from the stock connector and insert them into the new connector.
Make sure you lable what is what when you depin the stock connector.
dscoobydoo
I have now done two harnesses for this: one in the GC, one in the white SS.
I am bringing this back from the dead in case anyone needs assistance with this.
05 GD-STI
00- GF
05 GD-STI
00- GF
I needed you like 3 months ago haha. Just got the Ben to grab me the connector that came off the car and wired it in factory.
