Drive plate/Flex plate question...
RckyMtnLegacy
Post by RckyMtnLegacy »
I recently had oil leaking from my engine at a rate of 1 qt/half hour. I replaced the oil pan seal and bolts since it was coming from the rear only to have my worst fears come true and it was pouring out the very rear, I pulled the engine out and found that the drive plate where it bolts to the crank had spun a half inch while the outside which bolts to the torque converter did not move so with this minor twist it made a sharp cutting edge that pointed forwards and shredded the main seal up and emptied the oil out. Had anyone had this happen and will it happen again if I get a new plate. Also where can I find one? No parts stores seem to have any clue what I am trying to find.
Here is the problem:
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
jp233
Re: Drive plate/Flex plate question...
Post by jp233 »
wow... never seen that before. At least you caught it now before it got worse and could have potentially come to pieces, maybe really carving up the block halves. You should be able to find a plate online or at the junkyard, I don't know if that would be a part that would be newly manufactured new... (? rockauto?)
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
Alphius
Post by Alphius »
That's a pretty common failure. I've seen it tons of times on many different cars, including Subarus.
It shouldn't happen again.
A factory replacement can be had at a cost of $48 from SubaruGenuineParts.com if you go to parts and then browse to your car's year and model. It is under "Automatic Transaxle" and is called a "Drive Plate".
RckyMtnLegacy
Hey thanks! What s different between the Turbo and non turbo plate?
I'm not sure what the difference between the turbo & non-turbo flex plates are, but they do have different part #'s.
Non-turbo - 12332AA032
Turbo - 12332AA042
Alphius
Post by Alphius »
The part number I had was 12332AA040 but it wouldn't pull up on any parts sites. Good to know you have the correct number for him. :)
I don't know what the difference is either.
RckyMtnLegacy
Ordered from Subaru dealer in town and should get it Thursday.
It seems some of the online parts sites are showing superceded part #'s. Subaruparts.com is about the only one that still shows the new superceded part # when entering the old part #.
Alphius
Post by Alphius »
Legacy777 wrote:It seems some of the online parts sites are showing superceded part #'s. Subaruparts.com is about the only one that still shows the new superceded part # when entering the old part #.
It seems you are correct. Subaruparts does pull up the superceded number. I'll use them from now on. They are a little more expensive though, so I'll probably still just buy from the other site. :)
It bugs me that when you look up a part on the dealer sites through their part selector you don't get to see the part number. I use the parts catalog whenever I can instead, but this time it wasn't helping because I was missing the secret superceded parts website. ;) Lol.
Yeah, I'll use one if the part doesn't show up, and now that Jamie is back at Subarugenuineparts, their prices have come down to what they used to be. So I will likely use them for all my parts.
wtdash
Post by wtdash »
Legacy777 wrote:Yeah, I'll use one if the part doesn't show up, and now that Jamie is back at Subarugenuineparts, their prices have come down to what they used to be. So I will likely use them for all my parts.
Wow..that's great news about Jamie......SGP was headed off the cliff after she left.
In case she's not avl. I buy my stuff from:
Jason Douglas
jdouglas@mikescarffsubaru.com
Mike Scarff Subaru of Auburn
3025 Auburn way north
Auburn, WA 98002
1-866-456-3025
Mention you're on the forums for discounted prices and cheap shipping...NO I DONT GET A KICKBACK! :-)
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Mister Anderson
Post by Mister Anderson »
The N/A's have a smaller flex plate and the turbos have a bigger one. If you need the part number I will dig mine out of the shop. It only has like 4k miles on it so the part number tag is still there. BTW when I changed mine it looked exactly like yours, center spun.
Oh yeah I picked mine up from 1stpartsforsubaru and was told there was only 2 left in the country because of the tsunami in Japan trashed some of Subaru's warehouses or something.
91 black SS 5 speed (Canadian).... Closed deck EJ20G, fully built, V5/6 sti ra drivetrain, haltech stand-alone
93 silver TW 5 speed... rebuilt 22T with 20G heads, wrx ra drivetrain, otherwise stock.
73 kazen red VW bus riviera camper
RckyMtnLegacy
Subaru said they would get it in tomorrow...got it today! Install tomorrow! Replacing valve lash adjusters too
