I need a light curcuit that turns on at different times....
The light is a small 12 volt iincandescent.
In the key off position its off.
In the key accessory position its off.
In the key on position with engine off its on
In the key on position with engine on its off
Seems simple enough but I cant think of how to do it. Think of it as a Key on/Engine off indicator.
The simpler the curcuit the better.
actually....that's a little tougher then you think. There's not much in terms of electrical 12v power that changes when the key is in the on position, engine off, and engine on.
I can't think of an easy way to do this with a simple circuit.
I'll let other people chime in.
I can come up with a circuit that can do it based on the ECU's tachometer output signal. Basically, just set up a retriggerable one-shot timer triggered by the tach signal. Make the decay time approximately a fifth of a second. That way, if it isn't triggered at least five times a second, it shuts off.
But -- what's this for? There are simpler ways to do it if you don't mind a potential malfunction when something else malfunctions. Consider that the alternator charge idiot light on your dash behaves exactly as you describe, except that it also comes on when the charging circuit fails. If that would be okay, just connect one end of your bulb to the "light" terminal of the alternator and the other end to an "ignition" +12v source. You'd be putting your bulb in parallel with the stock warning light.
Hehehe... you're sneaky.
Well, you have your answer there. Just disconnect the end of the CEL bulb that's going to the ECU and instead splice it into the wire going from the CHARGE bulb to the alternator. The other ends of both bulbs already go to ignition +12v.
What are you doing that would cause the CEL to be illuminated when the car's functioning correctly?
I'd rather make it so the code doesn't get thrown in the first place, so that the light can continue to be a useful indicator of engine management problems.
