Here are the injectors:
And here is the MAF:
Thanks,
-Jason
Thank you, this helps. I don't have a mod list, because I'm doing everything at once basically. I'm planning on installing a td04, wrx TMIC, and MBC (basically everything you listed), plus the 440s and MAF. I already have a boost gauge installed.wtdash wrote:Hi,
Just to clarify...the JECS/AUTECS MAF shouldn't be used even w/the wiring mod noted above (no offense Mike!). It'll make the car run lean. Running the 440's won't properly compensate for this - I tried it when I had my Legacy and 440's - and AFR's were scary lean.
Since you don't have a mod list in your Sig, I don't know what you've done past stock, but suggest getting the upgraded turbo, an IC, boost gauge and MBC installed - all of which can be run on the stock injectors/MAF.
Save the 440's 'til you have the Rob Tuned EJ20G ECU installed, and aren't wasting gas 'til then.
GL,
Td
hellosubaru wrote:...... I'm doing everything at once basically. I'm planning on installing a td04, wrx TMIC, and MBC (basically everything you listed), plus the 440s and MAF. I already have a boost gauge installed.
I'll just wait until I can afford the Robtune like you suggested.
-Jason
I'm hoping the engine will be in top-notch shape, because it's currently getting a full rebuild.wtdash wrote:
Jason,
That all sounds good. I'd install in increments for the stuff you can. Why? So you can troubleshoot upgrades independently as you go.
You can do as others have done (not naming names) - throwing it all under the hood @ once, and the car may not even start. Not cool and it makes finding the cause 10X harder as the # of variables are compounded by each mod.
Plus the fact that the TD04 + WRX IC ('06-07, correct?) plumbing can be a challenge just by itself.
You can install the MBC along w/the other goodies now and 'CAREFULLY' play w/turning up the boost a bit. Fuel cut is @ 12.7PSI, and according to the Legacy FAQ you can run up to that if your car is currently running top-notch. Do some research on here of what others are running w/just the TD04 and IC.
TD
You and me both, sir....you and me both......mike-tracy wrote:Todd, keep em coming, I hate giving out bunk info.
Listen to this, I have done the "throw everything at it at once" approach and it is not a good one. I would run that engine through its paces first to work out any bugs. Also, if something is wrong with the rebuild, then the builder can't come back to you and say it was your mods that screwed the engine.wtdash wrote:hellosubaru wrote:...... I'm doing everything at once basically. I'm planning on installing a td04, wrx TMIC, and MBC (basically everything you listed), plus the 440s and MAF. I already have a boost gauge installed.
-Jason
Jason,
TD
