ECU interchangeability?
Bartek
Post by Bartek »
Hi all.
Anyone could tell if 22611AB010 is the same as 22611AB000?
I suppose my ECU must be shot.
Re: ECU interchangeability?
From this thread
http://www.uklegacy.com/forums/index.ph ... pic=107593
It looks like the 22611AB010 ECU is for the 92 turbo Legacy
and from this post
http://bbs.legacycentral.org/viewtopic. ... 60#p105260
It looks like the 22611AB000 ECU is also for the 92 turbo Legacy.
However I couldn't tell you whether the 010 ECU is for a RHD model or not.
Bartek
Post by Bartek »
Just bought it on ebay for 15 quids. Hope it'll work - whether it's from LHD or RHD.
Josh, looks like ECU is shot - every other possibility is excluded, I guess.
Ok, well hopefully this ECU will work.
Keep us posted.
Bartek
Post by Bartek »
It works. And I hope this will end my problems with intermittent stalling. Few hundred kilometer more and it never stopped so I guess it could be some fatal error in electronic guts, although I am aware it happens extremely rarely.
Good to hear! Hopefully that will solve your problems.
