UEL Header for 1994 legacy 2.2
SUBYLUV871
Post by SUBYLUV871 »
http://portland.craigslist.org/clk/pts/3270582199.html i saw these on portland cl and was woundering if they would fit my car. thanks
1998 legacy l wagon
1988 ford ranger prerunner (my baby
SUBYLUV871
Re: UEL Header for 1994 legacy 2.2
this is a duel port and im not sure if mine is or not.
1998 legacy l wagon
Post by entirelyturbo »
Yes, yours is dual-port, so those flanges will mount up to your heads.
However, the BD/BG Legacies had cat converters that were a separate piece from the manifolds. Your cat converter is part of the whole manifold setup, so you will have to ditch that and convert to the newer-style cat converter if you want to use those headers.
Or modify them.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
SUBYLUV871
no cat is fine with me. i dont DEQ where im at. well ill get them and give you guys a heads up on how it goes. thanks DerFahrer.
1998 legacy l wagon
SUBYLUV871
i was planning on picking up this header this weekend and the guy sells it from under me. cl flakes.
1998 legacy l wagon
