I'm not actually sure where it goes.
Awesome. Thank you. =)jamal wrote:little bolts- not very tight (18 lb-ft)
big bolts- really f'ing tight (101 ln-ft)
endlink bolts are 32 lb-ft.
I can't say I use a torque wrench for much other than engine assembly and lug nuts. Most torque specs are pretty standard for that particular fastener size and you could go by something like this:
http://www.engineershandbook.com/Tables/torque1.htm
Yeah that is the bolt I am talking about.Legacy777 wrote:Good notes/write up.
Yeah those long bolts are a real pain!!
Are you talking about the sway bar mounts that mount to the chassis? Is it one of those bolts that just spins? If so, there is a nut welded on inside of the chassis. If that was corroded or too much force was used, that weld likely broke and the nut is just spinning. You can either leave it or cut a small hole in the side of the chassis so you can put a wrench in there to tighten the bolt and/or try and reweld the nut back in place.
