Idle and start issues
2.2TLegacy
Got a couple of lingering issues that I am trying to hammer out with my build.
1. Cold Start
Car fires up quick (as it should) but rpm's shoot up to 2,500 and then slowly lower until the 'normal' 1,500 cold start idle. Is that a normal cold start idle progression? Also, how long is the cold start idle supposed to last? I experimented one morning and just let the car idle until warm up and it took about 10-12 minutes for the rpms to drop to below 1,000.
2. Cold and Warm Start (so like getting into after work or just running down to the store where it only sits for a few minutes)
So after the 1st start of the day, when I start the car the rpm's shoot up to 1,500-2,000 and then slowly drop until it gets down to warm idle. Doesn't matter if the car has been sitting for 5 minutes or for a few hours (obviously the longer it sits, the longer it takes to get to warm idle). So my question here is why do the rpm's shoot up so drastically, even if the car is up to operating temp?
Also, after the first start (where it starts quick as mentioned in #1) it take a bit of cranking to finally get the car to turn over. This is a recently developed issue (only the last few weeks or so). Before then the car would crank and start faster than my brand new VW ever does. So I am wondering what is causing the extra crank time before turnover.
Recent maintenance items:
- Coolant system drain/flush and refill
- All coolant hoses replaced
- Thermostat replaced (OEM subaru t stat)
- WRX metal coolant tank
1. Cold Start
'93 Stroker T-Leg - Weisco forged internals, 440cc gray tops, VF39, '06 TMIC, EJ20G heads & intake manifold, EJ25 phase 1 crank, JDM STi 5-speed mated to 4.11 lsd rear end
Re: Idle and start issues
Coolant sensor? I believe that 90% of cold start issues is related to that one sensor. It pretty cheep and probably should be considered when doing a tune-up.
Charles
2.2TLegacy
That was one thing that i was considering. Can those be replaced without doing a partial drain of the coolant system?
Yes, but you still need to burp the system.
Charles
Turbo_Carl
Very easy install.2.2TLegacy wrote:That was one thing that i was considering. Can those be replaced without doing a partial drain of the coolant system?
When I bought my legacy I was able to get it for $400 less than the guy wanted because of the check engine light. I ended up paying $1600. I replaced the knock sensor and coolant sensor and haven't had an engine light since. I would recommend taking care of the knock sensor too while your back there.
I have only one warning.
BE EXTREMELY CAREFUL WHEN TIGHTENING THE COOLANT TEMP SENSOR.
I overtightened and broke one. Good thing they are fairly cheap.
1993 SS. 5MT, STI Fuel Pump, Custom Intake, Diamond Coil Pack, Forge BOV, Hallman MBC, Custom AWIC, CNT 3" Downpipe, SLP Resonator, Carbon Muffler, TD04, FCD
1987 Ford T-Bird Turbo Coupe (Pikes Peak Hill Climb Car)
The idle revs sound about right, but may be slightly elevated, which I agree I would probably look at replacing the coolant temp sensor. The revs and now the harder to start may be an indicator it's on the way out.
2.2TLegacy
Ordered a new coolant temp sensor, i'm going to install it on Saturday and i'll report back here afterwards.
2.2TLegacy
Replaced the coolant temp sensor, seems to have lessened the symptoms listed above, car seems to locate the 'correct' idle a bit faster than before.
Crank time is still a bit slow after the first start of the day.
2.2TLegacy
day 2 update. Car seems to have issues idling for anything over about 10 seconds at full operating temp. It will stumble down to 500, back up to 750-800, back down to 500 and then either stall out or ramp it back up to about 1200rpms.
Next on the list is probably checking the IAC valve for correct operation.
I am experiencing the same issue. I was going to replace the coolant temp sensor and clean out the IACV.
Let me know what you come up with.
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
2.2TLegacy
Just decided to do an ECU reset. Seemed to have solved the issue for me.
I was going to suggest an ECU reset after replacing the CTS. Learned fuel & timing trims from bad sensors can be a real issue, so it's always a good idea to reset the ECU after replacing a suspect sensor.
Hopefully that fixed the problem for you and it will stay fixed.
devilzdriver
Legacy777 wrote:I was going to suggest an ECU reset after replacing the CTS. Learned fuel & timing trims from bad sensors can be a real issue, so it's always a good idea to reset the ECU after replacing a suspect sensor.
CTS replacement solved about 5 problems i was having between idle and startup 20$ part 2 min or replace totally worth it!
