I'm going to run ej205 heads on my ej22t stroker build, and I need to use the DOHC oil dip stick assembly.
Will my oil level still be accurate using the ej22t oil pan and a dipstick from ej205?
ej205 dipstick assembly in ej22t oil pan
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
Re: ej205 dipstick assembly in ej22t oil pan
Should be. I think they're basically the same pan. If you wanted an upgrade the newer 2.5 pan is narrower and keeps oil in the bottom better.
