rear spring perches not seated?
ride_child
Post by ride_child »
i just got done installing my tanabe springs on my new agx's and it seems like the upper perches arent seated properly. theres about a half inch or so gap between the rubber isolator and the upper perch. do i just not have it mounted correctly or will this become a non issue when installed on the car. thanks for the help.
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
Re: rear spring perches not seated?
Pictures?
Is this happening on the front and rear perches?
Yeah, any pictures you could post, would be helpful.
ride_child
its just the rear ones, but ill post pictures this weekend.
Kris
'91 Black SS - SOLD
macipusy
Post by macipusy »
Some lowering springs will be loose when the car is not sitting on them with it's weight. For example...my KYB AGX / Ground Control coilover kit is loose and the spring is free floating whenever I jack up the car.
This is a possibility if the lowering springs are short and stiff...not saying this is 100% your issue, just something to consider.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
It may be due to the fact that the springs are not meant for the rear tapered spring setup on the 90-91 legacies.
ride_child
The shocks and springs are both for a cc, same with perches. But yea it maybe the fact that they're lowering springs, I bought compressors, but didn't need to use them.
Kris
'91 Black SS - SOLD
ride_child
http://i1354.photobucket.com/albums/q68 ... 88168d.jpg
http://i1354.photobucket.com/albums/q68 ... a9de64.jpg
hope thats clear enough, let me know if i need to take different ones.
Kris
'91 Black SS - SOLD
Those look normal to me....
ride_child
ok sweet, i was just worried about the gap there between the isolator and the upper perch but i guess it wont matter when theyre on the car! thanks!
Kris
'91 Black SS - SOLD
Yeah, that will go away when the spring compresses
