Tick, Tick, Tick, Tick! Oh Brother!
edgarmoresco
Anyone have the solution to the ticking sound my Legacy is making. It runs OK for the miles it has but it sounds like a typewriter on steroids!
1994 GT Wagon all stock with 375,000+ original owner miles
It's the hydraulic lifters. They probably have junk in them. They either need to be replaced, or you can try running some cleaner in the oil to help dislodge the junk in the lifters. I recommend seafoam.
If the car hasn't had routine oil changes, and/or the lifters are gunked up too bad....no cleaner will help.....and the lifters will need to be replaced.
edgarmoresco
Hello Josh,
I'll try the cleaner but I think its age. Unfortunately, I don't see anything on lifters mentioned in my Chiltons. It doesn't sound like a Saturday afternoon job either. Whta do you think the simplest (read cheapest) way to approch this? I think I can get another set of heads pretty cheap its the install that would kill me.
petridish38
no need to take the heads out at all. I did it while the heads were off, but it is possible with the heads on the car.
the first few pages of this article talk about the HLAs
http://www.endwrench.com/current/winter ... Repair.pdf
I used it to disassemble my heads when i did my headgasket job.
i'm willing to bet that clogged or old HLAs are the poblem. I would order a new set of 16 HLAs, 16 HLA o-rings, some oil, and get to it. i'm not sure of the clearance you will have with the heads still on the engine, but u should be able to get a wrench in there. It could be done in a saturday (might take more than an afternoon, especially for me since i like to take my time)
It's as simple as:
removing air box, battery, and windshield washer tank
removing valve covers (replace those gaskets as well)
following sequence to remove rocker assembly on both sides
then carefully take out all the HLAs, put o-rings on new ones bleed in oil and replace following the instructions in the article.
reassemble following torque sequence.
No need to even take the timing belt off...
Good Luck!
Andrew
It's as simple as:
Good Luck!
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
I've done this on my kitchen engine and took about 5 mins/side. Of course it would take longer with the engine in the car, but it shouldn't be too hard as there should be enough room to get some wrenches in there easily.
nico, I have no idea what you're talking about.....what else would be causing the repetitive ticking......there may be some other ticking you have experienced, but from the orig posters comments.....it sure as hell sounds like lifters.
I think Nico's talking about masking the ticking by increasing engine speed a little. That smooths stuff out generally and increases oil pressure a little.
But you shouldn't really do that... the ECU is supposed to maintain idle speed with the IAC valve.
edgarmoresco
I could help but read your subtitle on not working. I lost my job today and find myself in the same boat. I don't live that far from Beverly. How about giving me a hand with it and maybe I can pick up something you want in exchange?evolutionmovement wrote:I've done this on my kitchen engine and took about 5 mins/side. Of course it would take longer with the engine in the car, but it shouldn't be too hard as there should be enough room to get some wrenches in there easily.
I'm usually free on weekdays (after this week) - PM me.
petridish38
while that wouldn't be such a bad idea, (provided he could find enough legacies) it would be wise to order new o-rings from the dealer.
I live in Florida and can't find any legacies in the local junkyards. but other places might not have such a problem.
209,000 miles!
209,000 miles!
He says he's near me and any Legacys in the junk yard around here are usually on their last leg and you'd have to pocket the lifters to get a deal as the bastards in the yards usually charge nearly what a dealer would get for such things (junkyard interior trim and such are still the way to go, though).
Come down to Tampa, there's usually a minimum of 3-4 Legacy's in the Copher's yards every week...There are 4 Copher U-Pulls withing 30 minutes of me (Tampa, Clearwater, Kenneth City & Bradenton), of course you'll be fighting me for partspetridish38 wrote:while that wouldn't be such a bad idea, (provided he could find enough legacies) it would be wise to order new o-rings from the dealer.
Or you could pick up some MMO and run that with your oil at every oil change, Subaru's love the stuff, keeps lifters quiet!
MMO = Marvel Mystery Oil...it really works!
2000 Legacy B4 RSK, 2013 BRZ-Track car, 2021 Forester Sport
- quasi-mod-o
petridish38
petridish38
Yep, and Sunday's too! They charge $1 to get in.petridish38 wrote:they open saturdays?
As of last Sunday tha Tampa yard had 3 Legacy's, a Blue Canadian spec '90 Sedan / blue interior / Auto / 2wd, a Gold '90 Sedan / beige interior / Auto / 2wd, and a silver '91 wagon / gray interior / Auto / 2wd. They were in the process of swapping out some of the rows of cars so there might be a few new ones out there now.
As of last Friday the Bradenton yard had 2 Legacy's, a red '90 sedan / gray interior / auto / 4wd and a gray '92 sedan / black interior / auto / 2wd.
As of last Friday the Clearwater had no Legacy's at all (bunch of Loyale's though! At least 15!)
I haven't been to the Kenneth City Yard in quite awhile...maybe I should get over there sometime....
There is also another yard off Hwy 92 east of Tampa that one of the Subaru tech's at Mastro told me about, he said there were 2 Legacy's out there last week.
