I am assuming the 15 and 16 (fuel injectors 2 and 3 inoperative ) are causing the 22 (knock sensor).
Does anyone think Sea Foam might solve the issue? I have never used it.
Thanks,
93 Touring Wagon 116000m
I call her Suzy.
ECU errors 15, 16, 22
JasonGrahn
After verifying the connectors, clear the codes and see if they don't clear, or if they come back right away.
yeah, it's worth a shot...clear them and see what comes back.
oppps...
I pulled one of the connecter off of one of the injectors and the little notch that holds it in place broke off, and I was very careful when I was pulling it off. Is there a way to fix this, and am I ok. I was thinking that I can maybe slip an O-ring in there and use this to keep it tight. I am also waiting a while before I pull the other connectors off.
[color=red][b]1993 Subaru BC Turbo Legacy (193k miles)
1971 VW Super Beetle
1989 Honda Elite 50
[/color][/b]
1989 Honda Elite 50
[/color][/b]
For some reason both of my passenger side injectors are like that -- the little tab that clips onto the harness connector is missing. They seem to hold in place decently anyway; I've put nearly 20,000 miles on the car since without troubles.
It might help to use a hair dryer or even a heat gun to make sure the plastic is warm before trying to remove the other connectors, to get maximum pliability.
I might try doing it when it's a little warmer too, and I will try the heat gun as well. I will just keep my eye on the connector and make sure it doesn't come loose...vrg3 wrote:For some reason both of my passenger side injectors are like that -- the little tab that clips onto the harness connector is missing. They seem to hold in place decently anyway; I've put nearly 20,000 miles on the car since without troubles.
1989 Honda Elite 50
[/color][/b]
1989 Honda Elite 50
[/color][/b]
the plastic just gets brittle. Mine did this on one of the older ones. Ran it for a long time....no prob.
