My car has leprecy
IggDawg
My car has leprecy
Post by IggDawg »
Yes, my Legacy went leper on me last night. I was driving along at around 75 on the highway. It was pretty packed and I had just gotten out of work. All the sudden I hear a loud BANG! like I'd just hit something pretty solid. I hit the brakes and my foot just sinks to the floor. I pump it a couple times and the feeling comes back. the brakes are really shaky. I figured I had a flat and the shakiness was due to that. so I pull over and whip my piece (flashlight :D ) out. I looked at each wheel. everything was fine. full pressure in all of them. So I took off again, relieved that I'd survived the hit apparently without damage. I wondered what made my foot go to the floor with the brakes, but whatever. chalk it up to gremlins.
I noticed my brakes were still real shaky, and they would grind a little as I came to a stop. "that's odd," I thought. I figured I should take a closer look at my brakes to make sure nothing was damaged. By this time I could tell the shakies and grinding was coming from the rear. I got out and inspected teh rear brakes. right rear... fine. I get to teh left rear. disc looks fine. caliper looks fine. hmm.. something isn't right with this caliper. It looks like something's missing... I can see too much.... Image...
A brake pad had fallen out. yeah. fallen out. and my caliper fingers were rubbing on the disc. it took a moment for this idea to sink in. a brake pad... fell out... huh?? isn't the caliper supposed to... I don't know.. um... kinda hold onto those pad thingies? It occured to me now how this had happened.
When I had first gotten the car, one of the first things I did was to check out my sweet vented rear brakes these things are famous for. I noticed some tool back in the day had replaced them with solid rears. prolly cause you can't find the vented disks anywhere and they're about 3 times as expensive. A friend of mine was looking on and said the calipers were prolly different too since solid disks are thinner. I remember thinking to myself "damn, those calipers look stock tho..." Well guess what. they were stock. I've known for a while that my rear pads are low. I get the godaweful noise when I back up that lets me know they are low. Apparently when they got low enough, they had enough clearance to fall right out of the caliper. so some poor soul got a 75mph backing plate in the radiator/windshield. and those things are pretty solid :D .
luckily the disc was not damaged yet. I'd been using engine braking and soft e-braking since I started hearing grinding. I got some pads at a local mom'n'pop auto store. 23 bucks. no big thing. threw them in last night. the pads on Subarus are so easy to change, I didn't even get halfway done with my beer before I was finished :D .
so yeah. my car's a leper.
IggDawg is cool.
-IggDawg
1994 Barcelona Red SVX LSi.
1990 CRX Si (for sale)
I know a little about Subarus.
Damn! Who woulda known there could be enough clearance for it to fall right out!
That also kind of sucks that you have solid rotors... They are kind of hard to find but they should be the same price as the solid ones. Part number 26310 AA112, lists for something like $70. I bet you could get them for closer to $50 from one of the online parts retailers.
the calipers and brackets are different for the vented rotor. If you have solid rotors in there, you really need to change them. The piston travel and clearance issues can do exactly what it did to your car.
The vented rotors are no more expensive then a normal set from the dealer. Since you're in the NE, call up liberty subaru and get a set of vented rear rotors www.libertysubaru.com
HomeSlice
Post by HomeSlice »
give jason a call at liberty. he is really helpful. every one is freindly over there. they got the lowest prices in the tristate. i was just there on tuesday picking up parts. great place. sorry to hear about the mishap.
-Jim
93BC"edm" 93GC 90BC R.I.P.
ciper
Post by ciper »
Wow, could this have also damaged the seal on the piston because it travelled farther than it was supposed to?
I once accidentally let a piston go out much further than it was supposed to... It actually pushed itself all the way out of the caliper, pushing the pads off in the process. I had let the brake line get pressurized when the caliper wasn't mounted on anything. The seals were fine after I cleaned everything out and reassembled it.
