Ecu q's
Someperson
Ecu q's
Post by Someperson »
I have an ecu from my 94 that i know works, have a 92SS w/ an ecu thats unproven. If i need to swap them out what might the differences be???
93 Winestone TW project
PhyrraM
Re: Ecu q's
Post by PhyrraM »
If they are both SS/turbo ECUs then there is no difference.
Someperson
Re: Ecu q's
I remember there being wiring weirdness between years
Re: Ecu q's
Yeah at/mt but its only a differencein the harness itself.
Someperson
Re: Ecu q's
Kk
Someperson
Re: Ecu q's
Can i just plug my 94 ecu in the 92 harness and run it?
Re: Ecu q's
If its turbo legacy ecu and haness, then yes you should be able to.
Someperson
Re: Ecu q's
k, just needing to be completely sure lol
Re: Ecu q's
Just to clarify, all the turbo legacy ECU's are compatible and interchangable between the 91-94 MY's.
Someperson
Re: Ecu q's
sweet
