Car won't crank, code 35?
Someperson
Going to have the starter tested cause the relay clicks but no crank
93 Winestone TW project
Someperson
Re: Car won't crank, code 35?
Starters good
FundamentalyConfused
The Haynes manual says code 35 is Purge control solenoid valve. Purge control solenoid remains in the ON or OFF position during operation. It also says refer to chapter 6 but that is read in chapter 6 and I can't find anything else on a purge control solenoid.
1999 Forester S 5MT 200,000 miles and counting.
1990 Legacy L Sedan AWD 5MT Retired at 369,471 Miles
i know this sounds funny, but did you connect the black wire to the starter?
Code 35 won't keep the car from starting. Sounds like you've got another issue.
Someperson
Green wire under the dash for the ignition was cut, gonna put a quick-disconnect for security porpoises
