I have aquestion about the Torque Chip.I would like to know what kind of power gains came of it? Pros and cons? If anyone dynoed the car before and after the chip? And what mods are done to the car?
I thank you all for your time,
Torque chip.
'93_5SPD_TURBO
boostjunkie
I don't think anyone's actually dynoed their car with and without the chip. Apparently, people have had mixed reviews - some good, some bad. However, a guy with an RS-T noted that he saw more gains with the turbo and the chip rather than just the chip. I think Legacy777 has one, but I'm not sure.
I have one.....I was getting weird issues.....and checked the wiring......a wire came loose....and not knowing how long it was disconnected.....I really can't give you a good judgement on it. I'm going to put it back in probably in a week or so.
'93_5SPD_TURBO
Legacy777, if you think of it let me know the out come when you put the chip back in. I also heard mixed reviews on the chip. I did hear the chip only cranks up the boost leaving the timing and fuel the same as stock.
I think I'm going to stay away from it unless I hear alot of good.
Thanks you,
Thanks you,
Al's done a lot of work on the chip recently.
milehial, would be the one to talk to about the chip, since he's developing it.
Subarureveiw.com has several people saying some pretty good things about the TorqueChip it has been known as the JC Sports Torque Chip, Suby Sports Racing Chip and Suby Sports Chip. One thing that I can guarrantee is that it will not increase boost.
AL(CO)
al@iwtu.net
AL(CO)
al@iwtu.net
The Torque Chip 2.0, at least, can't directly control boost. It appears to me, based on the installation diagram, that it modifies the vehicle speed sensor data and the water temperature data. It also reads the engine speed.
It seems to me that modifying the VSS reading can be useful to bypass the speed limiter, and maybe to trick the ECU into thinking you're never in 1st gear (the ECU sometimes limits boost in 1st gear to protect the transmission). Lowering the water temperature reading is a classic way of tricking an EFI system into running a little richer, and I've heard it said that one of the things the TC2 does is richen your mixture a little bit, and I've heard it does so to good effect. Keeping the coolant temperature reading low should also keep the system open-loop, so the mixture can stay slightly rich.
I don't know what's inside the chip, but presumably there's a reliable microcontroller that modifies these two readings intelligently. The result would be maybe a little more boost in 1st gear, a bypassed speed limiter, and a slightly richer mixture at least some of the time with the system kept open loop.
