ecu ground
turbo970
ecu ground
Post by turbo970 »
i been seeing threads about the ecu ground. so iwent and looked under the hood and i didnt see a ground wire under the intake which bundle connector should i look for a ground wire for the ecu
alexandermf
Re: ecu ground
Post by alexandermf »
I believe it goes to the ground on the back of the intake manifold driver side
turbo970
Re: ecu ground
Post by turbo970 »
i saw that part but i didnt see a ground wire unless its hidden real good. i 'm trien to trace it from the wire bundle to the intake so i can make sure its there and a good ground
Re: ecu ground
Did you see my post here?
http://bbs.legacycentral.org/viewtopic. ... 81#p409381
The ground wiring is part of the harness and can be rather difficult to see.
turbo970
Re: ecu ground
Post by turbo970 »
i seen your pic then checked my car and didnt see any wires . which harness plug should i trace? i got a another ecu on the way and i wanna cover all the bases.
