Coffee cup mod, de-snorkus How To
Re: Coffee cup mod, de-snorkus How To
Here's is my "coffee can" mod. I used an exhaust coupler I matched up at NAPA that is about perfect. Walker Part # 41974. Has pretty much the right inlet and outlet and is about 3/4" longer than the factory plastic piece(I didn't cut mine yet but it is not necessary) and I used a 90* black pipe fitting with a 1/2'' threaded piece and welded the 90* in the coupler with my mig. So for under $20 you can have your own coffee cup mod with minimal work. Enjoy!
1993 Legacy SS 5 speed sedan
Someperson
so, what is the purpose of said mod other than cool noises?
93 Winestone TW project
It removes turbulence and restriction from your intake tract. Not a gigantic improvement, but the turbo sound alone is worth it IMO.
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
free5ty1e
I like this; I think I might duplicate this version on one of mine. 2 still have stock resonators in place.abest10 wrote:Here's is my "coffee can" mod. I used an exhaust coupler I matched up at NAPA that is about perfect. Walker Part # 41974. Has pretty much the right inlet and outlet and is about 3/4" longer than the factory plastic piece(I didn't cut mine yet but it is not necessary) and I used a 90* black pipe fitting with a 1/2'' threaded piece and welded the 90* in the coupler with my mig. So for under $20 you can have your own coffee cup mod with minimal work. Enjoy!
...is that your FCD? Is it using an op-amp rated for underhood temperatures? Had any issues with it, how long has it been there? (and which version is it?)
-Chris
91SS 4EAT stock, 200k mi
