vf11 or td04?
ugaucin
vf11 or td04?
Post by ugaucin »
I'm planning on turboing my N/A legacy. But I was wondering what turbo was better. A Vf11 or TD04. Will turboing my N/A harm my engine badly?
Uriel
1994 N/A Sedan-Daily driver
1994 Touring Wagon 4EAT-Project car #1
rallyak
Re: vf11 or td04?
Post by rallyak »
If its n/a, only 3-5 lbs of boost it all it will take with the high compression. There is lots if threads on the conversion and every thing you need to know.
Charles
Re: vf11 or td04?
The td04 will be way newer, and have an outlet that modern intercoolers support.
CAV3MAN227
Re: vf11 or td04?
Post by CAV3MAN227 »
-In my opinion, there's really not much difference. VF11 would probably suit you better for this n/a application.
-Joe
wtdash
Re: vf11 or td04?
Post by wtdash »
ugaucin wrote:I'm planning on turboing my N/A legacy. But I was wondering what turbo was better. A Vf11 or TD04. Will turboing my N/A harm my engine badly?
I'd be more worried if it will harm it 'at all' : -)
RS25.com has a ton of info on this, too, and most use @ least a TD04- BUT for ease of install (no IC plumbing to deal with) and the low boost (5psi on wastegate) the VF11 is a good choice....and even cheaper than TD04's...but may be harder to find a good one.
GL,
tD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: vf11 or td04?
I know it's be done, but I really don't recommend just slapping a turbo on a non-turbo motor and band-aiding things like added fuel, engine management, etc.
In the long run I think you'd have less frustration and issues if you just swapped in a turbo motor and the added turbo sensors to run the turbo legacy ECU.
