Seat belt ECU
FundamentalyConfused
Seat belt ECU
Post by FundamentalyConfused »
So I had an annoying clicking sound coming from my trunk this morning. It was coming from the left side in the trunk. After I got the carpet out of the way I saw the culprit, the seat belt ECU.
Can I use the seat belt ECU out of a 91 wagon?
There's a 95 or 96 wagon in the same bone yard as the 91, could I use the unit out of this one?
Any reason why there's 2 different numbers listed for sedan and wagon?
Thanks for the help guys!!
1999 Forester S 5MT 200,000 miles and counting.
1990 Legacy L Sedan AWD 5MT Retired at 369,471 Miles
Re: Seat belt ECU
After checking the legacy wiki I found out that they stopped using auto seatbelts in 1995. That narrows down my search results for available parts cars.
Re: Seat belt ECU
The difference between the sedan & wagon is due to how the ECU mounts to the chassis. I suppose if you could take the guts out of one and put it in the other case. This is assuming that the seat belt computer from the 91 will work....which it probably should.
Re: Seat belt ECU
Thanks Josh. That helps very much.
If you're ever up in the mitten state I'll have to buy u a beer.
Re: Seat belt ECU
You're welcome.
If for some reason you find out that they are different other than just the mounting, let me know.
Re: Seat belt ECU
So I took a closer look at the circuit board and determined that the electrolytic capacitors, the black ones, had ruptured out the bottom.
I decided to replace them. The caps are on their way from china and I spent less than $4.
Here's hoping there's nothing else wrong with the components.
Re: Seat belt ECU
Cool!
Glad to hear it sounds like an easy/cheap fix. Like you said, hopefully nothing else is wrong.
